Something that has been said over & over and repeated on here---{If you can work on a
Briggs & Stratton--you can work on a Cummins.} Just probably the dumbest statement I've
ever heard. By some of the work I've seen performed on 855's through the years there must
be allot of Briggs & Stratton's that run like sh!t. Cat's 3406's are not forgiving but because it's
not a fixed time engine it has less moving parts-minus the Injection Pump, & water pump is
gear driven. Less gear train on the 855 because of the accessory drive-driving both compressor
and IP. The 855 is just as complicated what scares people about the 3406-A-B is the advance
& injector pump.
& injector pump.
