Travis Bales
I recently purchased a 953c . after check the final drive oil I noticed one side was alittle grey in color . so I decided to drain it and refill and check after running and more then likely drain again to make sure I get all the old oil out . I have figured out that it takes to-4 sae50 and I have drained the oil and just realized I'm probably alittle less then a gallon short on my sae 50 .. im curious if it would be OK to top it off with sae 30 and run for a day then drain and put sae 50 back in it ? any help is greatly appreciated..thanks
