1845c loses drive after shutting off
Geoff240ti
Saskatchewan, Canada
1993 1845c
Everything functions great upon startup. I can work the machine as normal, as soon as I stop the machine/lift the safety bar up and try restart the machine I lose all power to the drive wheels. Behaves like it's in neutral, no load on the engine. Have full control of boom and tilt and aux hydraulics.
I cannot find any electrical switches relating to the seat or bar. I adjusted the mechanical cables/parking pins and they work as they should.
It has happened twice now, 1st time I left the machine and came back and it drove again. Now it's stranded in a parking lot.
Is there a saftey switch not easily visible with the seat out even? Is there a plunger or valve that disables drive?
First time skid steer owner feeling lost.
Any help is appreciated.
heymccall
Western Pennsylvania
Remove seat and see if driveshaft between engine and pumps turns with the engine. There is a coupling that wears out on the engine flywheel.
That shaft only runs travel. Boom and bucket are from pump at rear of machine.
Geoff240ti
Just checked, it's spinning as it should.
There are a couple of sensors on the side of that drive pump, when I got the machine they were unhooked. I hooked them up before, but see no difference in operation now or before when they were disconnected. (I've tried both ways now again).
HATCHEQUIP
VILLANOW GEORGIA
All the 1845s ive been around on , the safety just engaged two pins one on each side to keep the machine from rolling when you lift up the bar or handles . the pump for the bucket and arms is on the front of engine when you open the back door the travel pumps one for each side are inline under the seat at the rear of engine. Have you checked the hydraulic oil level ?
And welcome to the forum
Geoff240ti
Thanks for the welcoming! I'll be hanging around here lots.. didn't want to start out this way though.
All the fluids have been changed and oil level is correct for hydraulics.
I did adjust the tension on the wheel lock pins, I did that after it lost drive the first time thinking there was a sensor down there somewhere. Ive thoroughly inspected now for saftey sensors and it seems they are non existent.
I just don't understand why I lose drive only after stopping/raising seat bar. Everything is a-ok until that happens.
I'm sure towing it 50ft to my shop door isn't the best idea either.
Geoff240ti
It had good power, it was spinning the wheels right before I shut it down to talk to someone. Mind you this is pushing some snow on ice, and the machine was only 1/2- 3/4 throttle.
I leveled our shop lot moving gravel last time I seriously used it and it didn't seem to have weak drive. It is leaking ontop of the drive pump where the right side linkage connects, visible in my video.
Did the machine have good power at the wheels or would it not spin the tires after it warmed up
HATCHEQUIP
VILLANOW GEORGIA
Standing in the bucket looking at the pumps on the left side there is a hose that comes from the filter this is the hose that feeds the charge pump that feeds the two travel pumps . you might want to see if you are getting oil from the filter to feed the pumps.
HATCHEQUIP
VILLANOW GEORGIA
just had a thought that filter might be higher than the hyd. oil level so it wouldnt run out at the pumps if taken loose unless you put a little air pressure on the tank . See if its higher or lower than the oil level.
Geoff240ti
I will be heading back to the machine in an hour or so, I'll have a good look at the inlet hose and filter. The hydraulic filter is located above the oil level I'm quite sure of that, but I'll verify soon. Appreciate all your help!
Geoff240ti
Went back to the machine, filter is above the sight glass.
Started it up, no movement. Shut off, checked hoses, connections, filter. No problems.
Jumped in and started it again, still wouldn't move.
Off and keyed on (without starting) to check the display panel without it running, then started it and now I had full drive again. I finished moving 2 small piles, drove it back to my shop. Removed bucket, parked it in the shop and turned it on and off a few times and it moved every time. The seat bar definitely has no part in disabling drive. It moved until pins locked it (I was gentle here).
I thought maybe hot hydraulic fluid temperature had something to do with it, until it didn't move the 1st time after sitting for a few hours.
A frustrating problem with it being intermittent now. I will need to get educated on how the pump system works. If anyone has insight it would be appreciated.
heymccall
There is NO electrical control of the travel (or boom/ bucket) on that machine.
Attempt to turn the driveshaft both ways with the engine off. I'm still betting on coupling failure. Maybe there's still a tiny bit of spline left on the coupling?
Geoff240ti
Is the coupling inside the pump? I posted the youtube video above showing the universal joints spinning the input shaft of the pump no problem. You can see me function the right drive with no movement in that video. I would really like to be something simple like the coupling!
heymccall
Alright, I watched the video...
So it isn't the coupling.
But, when you move the right travel lever, it looks like the shaft into the pump isn't rotating with the lever (the nut and shaft are fixed to the lever and should move in unison with the lever).
The shaft has two flats and the lever has a Double D hole in it. It looks like the double D, and or flats are worn out.Screenshot_20210113-211031_YouTube.jpg
Geoff240ti
I'll take a look into that! When I moved the lever it was ever so slightly as I didn't want to get launched into the bucket. Seems odd that when I do get drive back I get full movement equal on both sides. But I won't believe anything is good on this machine until I full inspect it myself. It's had some love, lots of new hydraulic lines and repairs but who knows how right its been done. Appreciate your help, good to know the coupler is not the issue at all.
