TSemenuk
Any recommendations on changing the dipper hoses. Should the boom be laying flat? Do I need to remove the cover from the bottom of the boom? Anything else I wouldn't expect?
Just set you boom down and take all pressure off of system by working levers with engine off. You may want to stretch the boom out a bit. You'll need a crowfoot wrench to get the lines loose and control valve and be sure and mark the hoses if you have to take multiple lines off.Any recommendations on changing the dipper hoses. Should the boom be laying flat? Do I need to remove the cover from the bottom of the boom? Anything else I wouldn't expect?
