1981 C70 Kodiak Cat 3208 Questions
cfherrman
Hays, Kansas
It's the same to-4 spec, I highly doubt it's cheaper
I just checked, the Irish 50 wt is $125. I checked around locally in January and the closest was $175, you will be shocked at the price.
Willie B
Mount Tabor VT
Electrician
I have found several times in life that name brand parts are less expensive.
In 1987 I had a catastrofic engine failure in an old International Harvestor farm tractor. At the time Central Tractor was the big other parts place. A used crankshaft was $1300. 1987 dollars, and almost fit. It would require machining to match the transmission shaft size.
A new shaft, head, combustion chambers, gaskets, cam bearings, cylinder sleeves, pistons, wrist pins, crank bearings & a long list of other incidental parts were $2500. from IH.
Eaton calls for either conventional motor oil 50wt or you can buy 50wt synthetic.
But straight 50wt motor oil will work just fine.
Willie B
Mount Tabor VT
Electrician
I've researched at length on the internet. I'm not clear what oil I should put in my axle. The nameplate is battered to the point of not being legible. It is Eaton, on a 1989 GMC chassis I believe rated at 20,000 LBS about 5:1 ratio. What does it need? I doubt the oil has ever been changed. It has about 15,000 miles on it.
