Got her fixed, ended up being a stuck transmission relief valve. Thanks for all the help guys
I'll get it later today not on site now but will have a look and let you know the dach is off can not see codeSerial Number would be a good start. There must be 50+ different models of D6R.
Take a look at the RH top corner of the digital window that shows the hourmeter. After you turn the key on and the panel completes the self-test do the words "SERV CODE" stay lit.?
That being the case the Serial Number on its own is worthless.......the dach is off can not see code
Hi, i think i have the same problem, can you tell me were is this relief valve? I check the pressures on the gear, sims to be ok, i think i have not the brake release pressure. TyGot her fixed, ended up being a stuck transmission relief valve. Thanks for all the help guys
Try starting a new thread. Quote your machine model and Serial Number. Give a complete description of what symptoms you have now and what the machine was doing leading up to the problem appearing.Hi, i think i have the same problem, can you tell me were is this relief valve? I check the pressures on the gear, sims to be ok, i think i have not the brake release pressure. Ty
