Smalltime,
Yea I'm working on 35, got about 2 months(weather permitting) left on mass
excavation. I'll probably be done with the big dog.
newjcb123uk asked if it got boring running these big hoes, in the mines, yes, on this road job its not bad, the cuts are small 200-800 thousand c/yds so I"m bringing down the pre-split, or pluggin' out, or pullin' finish grade 1 of the 3, 2or 3 times a week.
The last big road job had 3 cuts 2-4 million c/yds each, it was just bailin' dirt
"boring". I took this machine because it was brand new, and I wanted to see
if there was a big difference from the older machines, there wasn't much.
As for the speed set a 20 ton machine at 3/4 throttle and that's about it.
One thing the big hoes will teach you is effeciancy, I often test some of these techniques on smaller hoes, and get some odd looks for the work I put
out at 2/3rds throttle. LIVE and LEARN.
and no offence to the miners out there, I've always worked construction
and like to finish a job and move on, can't see myself digging the same hole
year after year. To each his own.
Thanks for all the comments
Gregg
