Hunter013
1XPFDB0X05N860710 C-15: MXS09731
We've been having this problem for a couple of weeks now. Truck will shut off like you shut the key off and because its rolling it will start right back up. The dash loses all power as well. Driver says it usually start to happen after he's running through the landfill loaded. There has been a couple times where the driver pulled off and it wouldn't start until he wiggled some harnesses and then it started. Other times the fuel guages will show full or empty when they are not. One/a few times the driver said after it restarted by itself, the truck accelerated by itself. Some times apparently it will shut off and then crank but not fire. No codes are logged. The driver said one time when it shut off it flashed the CEL 6 times. We've spent probably 2 days total looking over all the harnesses and connection and cant recreate the issue in the shop.
