3667-Open load error for power stage
Context:
ECU Power stages : Open load error on the EGR valve power stage.
Cause:
The ECU detects an open circuit in the EGR valve drive circuit. Electrical problem in the EGR valve actuator.
Possible failure modes:
1. Faulty wiring.
2. Faulty EGR valve.
3. Faulty ECU.
Solution:
1. Verify that the fault code is active.
Connect the Electronic Service Tool to the service tool connector.
To check for fault codes: Start and operate the machine.
A. The fault code is not recorded again. OK to return the machine to service.
B. Fault code 3667 is recorded again. Go to step 2.
2. Verify that the wiring and connectors are free of damage.
Inspect the ECU and the EGR valve. All connections should be secure, tight, free of corrosion, abrasion and
damage.
Inspect the harness from the ECU to the EGR valve. Verify that the harness is free of damage, corrosion, abrasion
and incorrect attachment.
A. The connectors are secure and the harness is free of damage. Go to step 3.
B. The connectors or the harness has damage. Repair or replace the harness or connectors as required. Return
to step 1 to confirm elimination of fault.
3. Measure the resistance through the wiring harness
Turn the ignition switch OFF.
Disconnect the EGR Valve connector. Disconnect the ECU connector.
Measure the resistance between ECU connector X-016 pin 50 and EGR valve motor plus pin. The resistance
should be less than 10 Ω. Wiggle the harness during measurement to reveal an intermittent condition.
Measure the resistance between ECU connector X-016 pin 35 and EGR valve motor minus pin. The resistance
Measure the resistance between ECU connector X-016 pin 9 and EGR position sensor supply pin. The resistance
Measure the resistance between ECU connector X-016 pin 39 and EGR position sensor signal pin. The resistance
Measure the resistance between ECU connector X-016 pin 24 and EGR position sensor ground pin. The resistance should be less than 10 Ω. Wiggle the harness during measurement to reveal an intermittent condition.
A. The resistance is less than 10 Ω. Go to step 4
Measure the resistance between ECU connector X-016 pin 35 and chassis ground. The resistance should be
greater than 20,000 Ω. Wiggle the harness during measurement to reveal an intermittent condition.
A. The resistance is greater than 20,000 Ω. Go to step 5.
B. The resistance is less than 20,000 Ω. There is a short circuit to chassis ground. Repair or replace the wire as
required. Return to step 1 to confirm elimination of fault.
5. Measure the resistance through the valve to chassis ground.
Disconnect the electric valve connector.
Measure the resistance through the electric valve pin 1 to chassis ground. The resistance should be greater than
20,000 Ω.
A. The resistance is greater than 20,000 Ω. Temporarily replace the ECU and retest. Return to step 1 to confirm
elimination of the fault.
B. The resistance is less than 20,000 Ω. There is an internal short to chassis ground. Temporarily replace the
electric valve and retest. Return to step 1 to confirm elimination of the fault
