2014 T770 oil filter question
wheel10
madison, wi
Picked up a 2014 T770 at an auction last week. Decided to change all fluids and filters. Went to my dealer and got a box full of filters. When I got home I notices there were 2 oil filters in the box. One with a 6678233 part number and the other with 7319444. The one that was installed was a Napa filter. A quick search online with my serial number said it should be 7319444. But when I got the Napa filter off, i realized the stud screw was the small size and the 7319444 is large. The 6678233 looks like it will fit, but is specifically says for bobcat v3300 on it. I have the 3800 in this machine, correct? So now I'm all confused. Any help would be appreciated
ozarkag
ozarks
7319444 is the hydraulic filter On the engine oil filter 6678233 will fit. I believe this to be a 40 micron filter. 6675517 would be the 17 micron as spec'ed in newer machines.
wheel10
madison, wi
Any idea why that filter specifically says "for bobcat v3300 only" on it then? Thanks
wheel10
madison, wi
Got it. Spoke with the dealer again yesterday. They have no idea why it says v3300 engine only on that filter. They verified that it was for sure the correct oil filter for the v3800 engine as well.
As for the hydraulic fan filter-the issue was bobcat show 2 filters for that spot. A 7319444 which looks like the oil filter only bigger and a 6692337 which is what my machine actually uses. They had given me both filters and I only needed the one
rbrown225
Athol, ID
This is the the filter list for my 2011 T770. It is a tier 3 machine
QtyWix #Factory #Donaldson
Engine oil filter1577306678233P551042
Fuel filter1331926667352P551039
Air filter - Outer17286652DBA5307
Hyd filter - Cooling Fan16692337P575347
Hyd Cap16727475
Hyd filter - Main17012314
Air filter - Inner17010031P636749
John V
North Carolina
Do you guys actually replace your hydraulic breather caps on a regular basis? My manual for my t740 says every 500 hrs
