treemuncher
That plastic is easy to work with and it will last a fairly long time. If you made it fit tight enough it will keep the grease in and most dirt out.
If your line is straight, I have used rectangular tubing as a guard. Just cut one of the narrow sides off and lay that open end onto the hydraulic cylinder. You can use heavy duty hose clamps for light duty but exhaust clamps are much better. If you weld the clamp base to the guard and wrap the threaded rod portion around the cylinder, it will be easy-on easy-off for repairs. Or lightly weld guard to cylinder with minimized heat.
Like this factory built one that is a welded on unit:
