EliteEquipmentRepair
OK. Thats the machine im trying to hook up to. It has a 3360 code for level 2 regen needed or something along those lines but the machine has been deleted so it should be an issue. It has the engine derated to 1800 rpm. So i need to hook up to it.
I have diagmaster 4.2.0 and a python adapter. I can not get it to hook up. Ive found 2 places online that says the python is no longer supported and you have to use the DST-i interface. The guy i got the software from says that is not the issue. He thinks its on the machine side. I have tested can H and L, power and ground. Zero issues. Everything should be there. Diagmaster recognizes and configures the python but when you try to connect to the machine it says "Interface not connected" Im starting to think the other forum i found that says python isnt supported anymore are correct. Any Kubota/Takeuchi guys out there have any input on if this is true?
