2021 cat 311f llr swing pattern changer
dscont
mo
I have a cat 311f llr with the pattern changer under the floor mat but it does not to seam to be set up correct.
Does anyone have the correct color code for with hose should be on which fitting?
Thanks
dscont
mo
Thanks guys here are some pictures.
In sae mode the excavator swings when pushing or pulling left lever
I realize in the one picture I pushed the control past just to show the number
Thanks again for any help
dscont
mo
I did just notice my number 3 is sae like your #4.
But no backhoe controls at all
dscont
mo
Talked to cat technical support today.
There is no backhoe pattern in the 4 way valve.
They sent me the diagram to switch the hoses on sae.
So any other thoughts would be appreciated.
KSSS
excavation
It doesn't take as long as you might think to change.
dscont
mo
I have a big plie of asphalt millings on my lot.
I'll just park on top till I learn.
Can't hurt much up there
