299D2 Caterpillar Lift Assist Spring gas Shock Support (Replacement) to Raise Cab
Sorry that yoke on the end of the gas strut is not a serviceable part from Cat and I have no idea where you might find one. Maybe the only way would be to use the existing one from the other strut and have a machine shop make one. It's basically a piece of round bar with an internal thread welded to a piece of tube. How much that would cost I have no idea.
TRexDirt
PA
Yes I can see that from CATs website, but these struts aren't special, Ive used them in many different applications outside of heavy equipment and they all have threaded ends like that, surely someone, somewhere has it, ill just have to get measurements and search
Nope, I was thinking the standard ball and socket type retainers.
That just looks like a threaded T.
Not something that hard to make.
McMaster may have something like that.
Or something else, check on Amazon.
southernman13
Florida,Ga,Tn
Retired
I replaced the hood struts on our pc200 Komatsu
With aftermarket. Much cheaper but didn’t last that long. Maybe 3/4 years idk. Anyway I just replaced again w oem. That hood is heavy and just so much easier and safer to just lift it
And not prop it up lol. Actually just replaced the two on our 97-2 Kubota. Only one was bad. I didn’t know till I replaced it and it worked fine. I already had both so I changed both of them and now have a spare. I couldn’t hardly raise the door I had to put the latch out and let it rest on something else about 1// way up to get in and out. Anyway gotem from bota they were said to be updates and stronger. Like 109. Ea
TRexDirt
PA
After further review, it looks like the actual part I need is 487-2952 this shows the correct threaded T end, and I agree for $240ish from CAT (not horrible) I can replace this spring which might be my route, just sucks because the spring is fine, just missing the end
