ccc enterprises
I have all the tooling to set up the top end ,
Experience: 30 years dealer experience
I have all the tooling to set up and replace injectors for 3114,3116, 3126 mechanical injectorsI’ve been thinking, since those are such a niche engine and many of us old 1.1 & 1.2 liter guys are aging out, there could be an opportunity to specialize, to some degree. Especially, on the marine side of the house.
Someone that could test bench governors and such.
Yer a poet.....Having the Caterpillar toolz
Having skillz,
Thats a good way to pay the billz.
Knowwhatimsayin?
No i set the top end up and have the experience doing soSo your selling some tools?
There quiet intence, image a i jection pump, timing, fuel setting , syncing each injector, valve lash, cutting all the injector seats if u can other wise drain the coolant and change all the injector cups press and coin them in and recut them big job not for the i experienced guy, inexperienced gut take 3 days to doI never played with one, but curious what is so special about setting the top end? No space to work in or?
Hmm I've done the top end on some interesting engines.
Sounds like a Detroit but once you have done 100s of them you can do it in your sleep....and pretty quick tooThere quiet intence, image a i jection pump, timing, fuel setting , syncing each injector, valve lash, cutting all the injector seats if u can other wise drain the coolant and change all the injector cups press and coin them in and recut them big job not for the i experienced guy, inexperienced gut take 3 days to do
Way way more complicated detroit easySounds like a Detroit but once you have done 100s of them you can do it in your sleep....and pretty quick too
Easy for me no doubt but intimidating for mostWay way more complicated detroit easy
If i could get the tools i would be that for the local area somedayI’ve been thinking, since those are such a niche engine and many of us old 1.1 & 1.2 liter guys are aging out, there could be an opportunity to specialize, to some degree. Especially, on the marine side of the house.
