hey guys im back again. Ive been working on a skidsteer. when it first came in it would raise and lower the bucket just fine but you could not turn in it. So we decided to replace both drive motors and the hydraulic pump. now we can turn and move just fine but when you go to raise the bucket itll stay in the same place or barely move unless you rev it up. im wondering if theres another valve that might of been damaged when the crew blew a line and ran the machine dry of hydrau. is there a seperate valve for the arms to raise and lower? the only thing we didnt replace was the small hydraulic pump on the very front. is that something i should look into changing or should i try replacing valves? thanks in advance
