I have a 320L that is showing a high voltage code. It all started with the govenor control intermitantly working the backup switches always worked then only the backup controls worked. Next the batteries died twice took them out and charged and load tested they were fine now they have not died for a month. Now the battery light came on so I take the altornator to a local shop and they tell me everything is fine right on spec. Still have high voltage code and light on 28.7 volts. The throttle still deos not work and can't do anything with computer because of the code being active. I have mettered all wires replaced the switch on the dash with no luck. I have the books done all I can think of and all anyone else I know. Does anyone have any ideas I am hopeing it is not the computer but it is looking like that is all that is left. Also the A or U code that lights up in front of speed setting when you flip the manual govenor or pump control works intermitantly but the backup controls work just don't put the letter on the screen. Any help will be appreciated.
