oarwhat
Checking the oil I found a coating of sludge. Pulled the fill plug and found a small amount there. Hard to describe. like whipped oil,very light, foamy? Ideas? Oil is nice and black. Anti freeze is clean.
If you don't want to taste the sludge, you could try the sizzle test, drop it on a hot metal surface, you know it will sizzle from the water, you're interested in if it smells sweet or not. An SOS sample is pretty cheap also.
That's a 3306 in the 980 B right? Have you checked out the crankcase breather and the tube down the side of the block to make sure it is venting right?
