Good day, I’m currently having hydraulic issues with a 336F (S/N RKB10057) (10,000hrs on unit) and I’m looking for some advice. Customer complaint was slow bucket function and when tracking, all functions are slow. Arrived at unit and checked all the basics, fluid level, condition, etc. No active codes. Checked pump pressures and found that pump #1 (which controls bucket and left travel motor) was not coming up when bucket or left travel is actuated. The pressure will reach relief pressure when bucket cylinder is at the end of its stroke. Cut filters open, found them to be clean and they had not been recently replaced. Swapped pump controllers and issue stayed with bucket circuit. Swapped main pump feed lines at the control valve and issue stayed within bucket circuit. My question is: why is the bucket not causing the pump to stroke up? I should add that when moving the boom or stick both pumps are stroking up properly.
