Nimitz4300
hey guys! ok so I picked up a 3406c and im gonna use the engine for another truck. its bone stock with 398,000 miles. the wiring harness is crap and i found a harness from Cat for $488 but i also have the option to convert it to mechanical. my father in law has a B model pump i can use. now my question is if i convert it i want to match it as best i can i do not plan on turning the engine up much. i have the 4ck15380 engine the tag does not have the AR number. all i no is its 350hp at 1800 with 10 timing. i have a set of 0r-8289 injector nozzle's but no one seems to no what injector numbers are for what arrangement. Cat website serial number break down says i have the pistons(7e-0292) that match to the 15.6.1 compression. if i could get 435hp id be happy but it does not have to be that much for what im doing with the truck. any help would greatly appreciated im looking for injector numbers for a 435 or 400 hp motor and turbo combos i could try. everything else i got a pretty good idea. Thanks!
