Jeremy Whittaker
I finally started putting my 345BL to work on my property. I believe I read in the manual that in order to fully pressurize the hydraulics you should extend the stick all the way out and turn it off(don't recall where I read this). When I do this the stick will stay up for about 30 minutes to an hour(wasn't timing it just working on other things and seeing when the bucket was down). I don't have any leaks underneath and I tested it pretty well before I hauled it up there for leaks. So I'm wondering on an old 1998 machine like this is 30 minutes to an hour pretty standard? Or should this be more "infinite"? I changed out all my hydraulic oil and filters. I'm an amateur so there's a chance I did something wrong. I'm trying to determine if I need to open up the two filter chambers and replace/check the rubber o-rings perhaps air is leaking from the chamber causing it to not get fully pressurized?
I also believe this may be related, when I try to turn the tracks in opposite directions to spin the excavator it just stops. It won't actually spin around. In order to turn the machine I have to do this maneuver where I go both tracks forward/backward (which works fine). Then I'll keep one track engaged while letting up on the other. This usually allows me to "inch" my way around so I can spin the machine.
Anyways, looking for some feedback or things you guys think I can check out based on these issues. Thanks as always.
