4 Way Blade Adjustments
Girth_Brooks
Scranton, PA
Mechanic/Welder, Operator/Labor
We have a komatsu 65ex with 4 way blade and had the arm, with hoses, slip off a couple times before i got it tuned in. Should the 2 tie rods, from arm to back middle of blade, be pulling in to hold everything square or maybe relaxed. I feel like im missing something.
DanielB
Glasgow KY
Retired, Heavy Equipment Mechanic of 30 years
This sounds like your trunion ball is worn bad. If you take off the back cover or we call it the cap. is the ball still rounded. If it is more flat where it contacts the cap. You should either replace it. Or have it built back up with Weld. A then shim it where it will turn with little to no resistance.
Welcome to the Forums DB! Glad to have you.
DanielB
Glasgow KY
Thank you , Hopefully I can be some help to someone.
Girth_Brooks
Scranton, PA
I have replaced the ball on each side few years ago and the caps. Its probably the arm side wore to **** the more i think
bam1968
IA
Excavating Contractor
I have the whole D65 EX-12 manual right here on my computer. I would be more than happy to email it to you if I knew how to do it. Stuff like that gets over my head pretty fast.
