heymccall
Needed to replace the 25 year old lift pump on one of our 1YR 426Cit backhoes.
Trapped between the engine and main frame, it was a little tedious to get out, but, fortunately, it ran on ether long enough to raise and lock the boom.
Here's the problem....
Original part number 121-3220 has been replaced (updated) via service magazine and the parts ordering system to a 201-0877, BUT, Perkins boxed a bunch of them wrong. Hey I get it, it happens. The makes me angry part is that when I called the dealer, the counter guy "knew" about it AND yet they are still in inventory. So, 45 minutes times 4 just to chase wrong and right part, plus 1 hour times 4 in road call, just for a $45 pump.
Having done work on quite few Perkipillars, I knew to order the line olives (2 @ 067-6269).
The makes me frustrated part is that they were aware at my branch, but not at the DC. They are now, and so are you.
Not only does one port point at the engine block making connection impossible, the cam follow arm is too long to allow bolting up. I could've reoriented the cover and modified the fuel lines, save for the arm being too long.
