Elmeche
Hi all,
Data for lift:
48 volt JLG 3369,
Ser Num: 0200040894
Model:3369
UPC code:709264021320
maybe 1997year according to some text in parts' labels
DC Motor controller: AU1830 (N)
Part Num:631/42030
Ser Num:12976153
Text on it: ENGLISH-1701760
What is the purpose of "S" terminal?
Connected or disconnected terminal - the state is the same.
The state:
Driving wheels are lifted in air! On the ground it drive the same manner.
The wheels turn slowly in each direction with tacho, without tacho accelerate again slowly
but up to triggering the error check for tacho, the PWM on "A" terminal is OK and is properly changed without tacho up to error appear.
All contactors work well, all wirings also (drive acceleration, pump acceleration, high and low switches, tilt sensors are OK,
directions, tacho output- all checked up to 17 pins controller connector, accumulators also in good state.
No shortcuts or broken wires to motors and windings.
I have not a service manual / wiring diagram that even slightly fits this machine exactly ( use several manuals for different machines).
Now I'm to the point to open the controller, but it is heavy sealed and it is so risky act.
Any help will be accept with great appreciation!
Thanks!
Data for lift:
48 volt JLG 3369,
Ser Num: 0200040894
Model:3369
Part Num:631/42030
Ser Num:12976153
The state:
Thanks!
