580B little black smoke
Silvermopar
Nebraska
I’m getting a little bit of black smoke out the exhaust on my 580b. It’s got the 188 Diesel engine. It’s not obvious from a distance but noticeable from the seat. I don’t notice it until the rpm is over 1000. Does this sound about normal for these engines or should I be checking into it more. Again; it’s not a lot, just enough to notice.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Try adjusting the pump to engine timing by turning the inj pump in its slots..
Make a reference mark FIRST..
Tighten the mounting bolts after each adjustment..
DO NOT turn the pump while loose. (Like a distributor)
RES
Pumpguy, do you mean don't turn while running? I know you are the guy for pump repairs and will get mine if/when it needs it. But how would you turn it if it was tight. I need to check mine too. Just got a 580b, oil was changed religiously but other things were neglected and it puffs a little.
