DirtyHoe
I'm rebuilding the loader control valve on my 1980 580C. I don't think the insides have seen daylight in 40 years. The spool seals were leaking and most of my power beyond o-ring was gone. I've read the service manual and searched online for any information on what is acceptable wear on the main relief valve(pilot plunger and seat along with the poppet and seat). There are ridges and burrs that you can feel with a fingernail. Do they start leaking at this point? Some of these parts are no longer available to purchase. The service manual says to replace, but don't mention what the tolerance for wear is before replacement.
On the engineering side of things, why don't they seal on a chamfer like a load check valve and a secondary relief valve? These parts look brand new because they have more surface area to seal on. It does not make sense to me why the relief valve shuts off on a sharp edge instead of a chamfer. I could re-machine these parts to remove the wear grooves, but the would change the depth of engagement and diameter of the taper. I'm guessing this very small change would make it relieve at a different pressure. My concern would be the springs would not have enough adjustment to function at the correct relief pressure. Basically, I fear I would not be able to recalibrate the valve if things go wrong. Then I would be screwed trying to find good used replacement parts.
I can't believe the amount of innards in a hydraulic valve. AMAZING
Don't worry, I took lots of pictures...
Thanks for any help with this,
Steve
Steve
