580c parking brake lever
broo1874
Newark Valley NY
Parking brake lever D75370 is broken and discontinued. Does anyone know if there is a newer part that can be used instead? I see some for sale for newer models that look similar but don’t know if they are the same because the part number is different.
Or if anyone knows where I can get one.
Any help would be appreciated.
RDC_580C
VA
The bucket and/or outriggers are a far better and safer parking brake, even a cinder block tossed behind a rear wheel will hold better.
broo1874
Newark Valley NY
I have been using the front bucket. But I have the brakes all taken apart to rebuild them so I might as well fix that also if I can.
RDC_580C
VA
If you need the entire assembly, give Dale Weiss a call, http://e-backhoeparts.com/
It's really just a cable that gets pulled, so it probably wouldn't be super difficult to fabricate up something or possibly make some other type of lever work in place there.
Billrog
Armstrong, British Columbia
band mill , backhoe and dump truck
Just looked a a new one I happen to have , the rivet that holds the handle usually goes . I drilled it out and replaced it with a shoulder bolt . If you have trouble finding a new one I'll send you a pic. of the one I have and you can have it for $50 plus shipping if it's the right one.
