DirtyHoe
My Case 580C steering system was toast.
List of problems:
Below are some pictures of the start of my complete rebuild. More hours into the repairs than I want to admit. Lots of welding, grinding, machining, sandblasting, and painting. Not to mention replacement parts too. Plus a lot of head-scratching!
The Axle is too heavy and awkward to position on the milling machine so I cut the yokes off.
The hub bore is just a little oversized...Haha. The inner bearing balls were dust.
Seal area destroyed:
List of problems:
- Dirty fluid
- Low pressure
- Leaks
- Spindle seal destroyed
- Inner bearing destroyed
- Spindle and hub damaged
- Ball joint tapers loose(egged tapered holes on the axle and spindle assembly)
- King pins and needle bearings destroyed
- Egged out yokes
- Stripped tread on hub
- Bent tie rod tube
- Bent and dented rims
