flyingfrog509
Well got my new to me Case 580ck. Had the previous owner run it for about 35-45 minutes, checked the oil, checked everything it all seemed OK. Got it delivered and two hours into digging out stumps I hear a noise from the engine.
To make the story short I found a broken valve intake valve spring on #2. Valve seems ok, both pieces of the spring stayed on the guide, & both retaining clip 1/2s were stuck in the "mud" per say.
Q1) So with all of that said, does any one know how to check the compression on cyl #2? Don't have a spark plug hole like a gasser.
Q2) I'm wanting to just replace the springs with the head still on in an attempt to just get some more work done before having to do an engine rebuild. Is this just a really bad idea? Engine starts up perfectly (even when the spring was broken) Any steps I should take here?
Q3) How much of the oil sludge should I clean off the top of the head & with what? I'm planning on changing the oil just in case stuff falls down into the engine.
Q4) Should I drop the oil pan, clean it up, & check for metal chunks?
