syndy
I was up in NC for the last couple of weeks and my 580 ran like a charm except for the right brake which never worked for me. They are dry brakes with regular gear oil in the transaxle. I suspected an oil leak into the disk area since I bought it. I removed the cover, (what a bear, near killed this old man) and about a coffee cup of gear oil leaked out. Pulling out the guts, everything was soaked in oil.
I just got home tonight and have not unpacked my trailer but the disk looked good as far as material thickness. Can I bake these out with a small torch, I have read that some on here have tried?
I will inspect the other parts that I bought home and replace any bad parts.
The seal is an (A179054) and appears to be in the back side of the differential brake housing and I am assuming I need to remove the housing to get to the backside. Would this be possible to do, lets say sitting under the machine out on the farm? I would put a sheet of plywood down as a working surface.
What holds the differential brake housing to the transaxle? Right now it is on the axle with all the bolts out. My manual says there are two (FERRY) bolts holding it on, never heard of them before. The parts book shows no bolts at all meaning the longer cover bolts do the job. Some confusion here?
I have the floor removed and that only helped with getting to 2 of the upper bolts. I can't even look into the housing as things are very close to the frame. I am thinking of removing that one wheel using a winch off the ROP and the back hoe to hold it out of the way, is that of any help?. I am working by myself so any ideas would help. BTW there is liquid in the tires.
