I have a new to me case 580 SE with a 4-390. Runs sweet, has a few leaks, looks a little tired, my first backhoe.
Purchased and put to work around the acreage immediately digging trenches and doing what a new backhoe owner would do.
Noticed the oil light came on at idle when hot a couple weeks ago. Figured it might just need an oil change. Put in 30W and a new filter. No change. Removed the pressure switch and verified it works and closes @ 8 PSI which surprised me it switches so low. Purchased a mechanical gage but have not yet installed it. I'm pretty sure it will confirm my suspicions.
I've read through piles of notes on this issue but most point to a missing plug after a rebuild.
My next attack will be to remove the pressure regulator from the cooler just below the filter and see what it looks like.
Anyone have any other suggestions?
