650J blade will not lift
PrinceHQ
Arkansas
Has anyone ever seen a solenoid that looks like this? The far left one is the blade lift and I’m not as familiar with John Deere but I think that might be an aftermarket solenoid. I’ve tested everything, including the rigged wiring and I’m failing the solenoid.IMG_0830.jpeg
PrinceHQ
Arkansas
Okay the serial number is
1T0650JXLA0193572
The machine throws a code for the blade lift solenoid shorted to ground once you try to lift or tilt the blade, you can angle the blade all you want until you hit either of the other two functions and it throws the code.
The code is 523781.4
PrinceHQ
Arkansas
The white wire is an overlay wire for the (P62 Red) wire that someone did in the past. That of course was the first thing I checked, I made sure it wasn’t shorted to ground or any of the other wires in those connectors, I also completely by passed it with my test leads and it stayed the same. The red wires that are twisted together are where they cut off the (P62 Red) wires. I’m not sure why they twisted them together, I untwisted them at one point and nothing changed. Also I could never find the LED that the troubleshooting is talking about but I’m not familiar with Deere, where would that light be located.
