Freedom6178
Hey guys I'm having an issue with my 580ck. I was using it to transfer some dirt from my pond I just dug to our trail ends
. OK so what would have been the second to last run I had it in 3rd gear low (std clutch) and kinda gave her (full throttle) only for a half a min or so to get to the nearest trail. I dumped that load but didn't spread it out. I headed back to what was left of the dirt. I tilted the bucket shy of full dump to scrape the remainder into a pile all was good till i wanted to do it again but the bucket would not raise. I tried the Backhoe too and it is the same way. Now it technically would go up a fraction each time I'd pull the lever back and it sounded to me like the fluid was going into bypass but all this is pretty new to me tho I know some of hydraulics due to my work. I thought OK old mach i have some seeping hoses and cylinders maybe I'm low on hyd fluid I added some but it wasn't to low. hurm I'll check the filter (Oh what a mess haha opps there went a good amount of fluid on the ground
) Well the filter was pretty dirty AND low and behold whats this small chunks of some orange rubbery stuff wait its whats left of an O-ring now where could that have come from :beatsme . Well now I'm stuck
where to begin looking?? This was a fairly thick o-ring I measured it to be 3/16" thick and if the curve of it was anything to determine the size it would have been pretty large too probably in the 2" to 3" range purely a guess hard to tell when the chunks are about half an inch long max. Any Ideas where to begin looking? I have a new filter otw. (Note: the machine in up north about 3 hrs away so I wont get to try anything till the weekend)
Thanks in advance
Thanks in advance
