I'm trying to help a buddy with his 700H that is now overheating. Ironically he bought it used and until 3 weeks ago he couldn't get any heat. For real no heat, in the cab that is, (I forgot to say he's running this machine in Alaska pulling a drag building winter trails) anyhow... I replaced the valve at the block as it was mangled with pliers and we couldn't move it either way. I fixed broken wires on the temp control valve, replaced the temp control valve, he plugged the radiator off with cardboard, nothing! We figured a thermostat and a water pump would be a good start. Around the end of January I pulled it in to check this out, replaced the water pump with no event, couple scores in the wear plate at the back but nothing major. I went to replace the thermostat and discovered there wasn't one in there.
So here we are now everything back the way it should be and now it's overheating. I'm wondering if there's something I'm missing, maybe a vapor lock? Maybe there's something I'm missing, that caused the previous owner to pull the thermostat?
Thanks for the Help!
