rmllarue91
Hey hef 700h 907570 right track very slow erratic. No rpm in controller for right motor. Swapped senors. Motor rpm displays on right track now not left. changed speed sensor ( no signal out put voltage ). adjusted throttle linkages did first part of calibration it passed. Shut machine off ran it around tracking to right but runs good enough figure it calibration time. When I look at controller f372 f383 both speed sensors output voltage in 2.5 ish volts...... Used one was switching low to reference voltage fine before. Re adjusted air gap no change on both. On sensor wire black is steady ground red is 5 volt reference and green seems to be 4.5 volts in ? And white is only showing 2.5 ish volts. on controller both rpms for motors seem accurate. Any ideas welcome
