72 CASE 450 DOZER RUNNING HOT
born2ride
Flemington,NJ
Automotive Tech
Hello,
The issue is when pushing dirt the temp climbs up to about 220 and start pushing coolant out, I have replaced the cap, and it still does it. There is no thermostat in the dozer. ,tracks are clean of debris. Not sure about the fan operation as it pushes air through radiator toward blade. I am in the automotive field as a tech I found that odd it pushes air through verse pulling. Is this normal on this unit? I forgot to looks at tranny temp when this was happening. Looking for some input on fan and other reasons it may be running hot I have not though of. TIA
Tinkerer
usa
Look in the radiator through the filler opening for solder bloom encircling the tubes.
It quite often restricts coolant flow and will cause overheating.
born2ride
Flemington,NJ
Automotive Tech
born2ride
Flemington,NJ
Automotive Tech
I am finally back on this issue of running hot in summer temps, I have replaced the thermostat, checked fan operation , washed out radiators fins, I sent the rad out to fix a crack and to be flushed a 5 years ago. This is a new problem with in the past couple of years. I only use it once in awhile but need it to work when I do. lol The coolant has always been clean with a of mixed 50/50 using distilled water since I have known this machine. I have no coolant in oil or oil in coolant.
I read another post for a case 450 that mentioned Fuel injection timing can contribute to overheating. I have never had the pump off , can they slip out of time? Is there an easy what to check correct timing to rule it out?
At the end of year I was running out of fuel due to crap in tank, Meanwhile I have cleaned this tank a few times already throughout the years of owning. I would drain tank, removed the large cap on bottom,wipe out a good amount of brownish sediment, then use some emery cloth to removed any scale, brake clean out tank again, wipe dry and refill also keeping tank full and used additive yet this brownish slug comes back, I have always made sure quality clean fuel goes in my machines since making that mistake one time only!! Any thought of how to clean tank? I was think of using coke cola or vinegar.
Could lack of fuel volume cause lean condition and make run hot? If so How can I verify this?
Would trans temps cause this issue? I noticed my gauge stopped working. It was a newer VDO gauge I put in when I got machine
Lastly is converter psi normal in video?
TIA
1978case
AR
Retired
