thats the issue now, you dont really know what else may be cracked or wrong, just because it ran doesnt mean it wasnt going to go boom soon after..just my .02 cents...it would be a darn shame to rebuild and then shortly after have the block fail...
Have at it... you already know what the worst case scenario is.
LOL, those are stout little engines. Would be a good idea to use new rod bolts, if not then locktite them good......they like to loosen and fall off on that motor throwing the rod thru the block....
usually some sand paper, a wire brush and some elbow grease worked well. If I could get a flap wheel into it or the sanding disc on a grinder that really helped.
So did you find out if your LED lights were rated by the pair? if they are the 2x6 lights they should be plenty bright but they send the light in a 180 degree sphere. decent cheap flood lights. I like the latching switches.
