I have one of the dreaded "Hate 2" detroit diesel in my 1985 Ford truck. I cannot locate any mechanics familiar with this engine in my area and that leaves me to try to work on it. Would anybody have a shop manual they would be willing to share with me? It seems it has been dumping fuel into the oil and I believe it finally collected enough in one of the cylinders to lock the engine. Coolant level has not dropped is the reason I am leaning toward fuel instead of coolant.
To work on this thing, it seems I will have to pull injectors, but I don't have the tools necessary to do this job. With only 1 truck that may blow up any day I cannot justify the expense of the nice Snap On timing set that is recommended. I have read something about some rods to measure the injector height, but have only found a couple brief references to them and no mention of how to use them or where they would be available.
I wish I could afford an engine swap, but with a 35 year old truck that I use a few times a year on the farm, I cannot justify the expense of another engine.
Other than dropping it in the lake and using it for an anchor, does anybody have any suggestions?
Thank you for any information you can provide.
