My ford 7.8l F800 just started shutting off after 15-20 minutes of idling. About a week ago there was a puddle of fuel underneath the fuel/water seperator and thats when this whole issue started. I replaced it, primed it, and the truck started fine but once again it died. Even if I primed it again, it would just keep dieing after 15-20 minutes. I later noticed a little stream of fuel coming from one of the lines which I just replaced today, but its still dieing after 15-20 minutes. I took it for a drive today after replacing the line to see if it would die while driving, and it acted normal(as in no cutting out, or any problems)
When I first got the truck it never did this. It has a low idle at 500rpm, the original mechanical fuel pump, and no leaks from what I can see. All 3 of the fuel filters have been replaced.
Anyone have any ideas?
