- Joined
- Jan 21, 2007
- Messages
- 13,532
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
So my baby is sick and I need some help. The warning light (!) is flashing, stage one warning - just the light.
Backstory -
I changed the fuel filter and it sat for a few days. Cranked it up to move it across the site and the light started flashing. Plugged the computer to it and there was a "fuel pressure" warning code logged. ( I had a friend come over with the software as I do not have it). Pulled the sensor out of the fuel line that runs to the primary fuel filter and put a gauge on it. It read 100 PSI at full throttle, I do not have the info on what the PSI should be.
I changed the fuel filter again, pulled the plug at the base of the primary filter and flushed it out with the electric primer. I also broke the fuel line from the primary filter base that runs to the top of the engine - flushed it again. Plenty of fuel is making it to and through the primary filter, however I was not able to flush the line that runs to the top of the engine.
After I did this I was thinking it probably was a bad fuel sensor. This sensor is mounted in the line running from the fuel pump to the primary filter base. I changed this sensor and the (!) warning light is still flashing.
3995.5 hours on the clock.
Questions -
Is there another sensor in the fuel line? I have looked through my parts manual and didn't see anything.
After looking through the parts book there is a fuel regulator mounted where the main fuel line that goes from the primary filter into the top of the engine, at least that's what the schematic shows. I am not sure what it's function is.
My worst fear is the fuel pump is going out.
The filters are changed every 250 hours and all fuel that goes into the loader is filtered from my slip tank. I run a fuel additive as well and I try to keep my fuel as clean as possible.
Any help would be appreciated. I am not mechanically inclined, my skills encompass the user end of yellow iron.
Backstory -
Questions -
