Can't disagree with ya too much on that one, she's a beast.
I'm even amazed on a regular basis by that 931, had a big 12,000lb+ concrete pad that fell on one of the JCB back-hoe loaders while we were undermining it. When it fell in the hole, we had to use the Hitatchi EX200 (tracked excavator) to get it out of the hole. That thing was standing on its toes, and inching that thing out of there. Ended up using the EX200 to finish up with the digging and backfilling, then sent it off to a job site, but left the concrete pad in the middle of the corral. Nothing could even budge that thing, we even tried using multiple tractors at once, but nothing. So it sat for over a year.
One day I had the 931 nearby, so I figured I'd go play with the pad for kicks. To my amazement, it pushed it no problem! I just went up to a corner, put a bit of up pressure, then pushed it out, around a corner, through some gates (a 12x12 pad through a 14 foot gate). I was even able to stand the thing on end! I didn't have quite enough reach, but I still could have flipped it over. I was amazed such a small machine could do so much, so from that point on I've always had a soft spot for tracked loaders, and I'm stilling trying to determine just what was the largest one ever made.:beerchug
-Josh
Gives you an idea of the size next to some of the tractors that couldn't budge it:
