rditz
I have a 955-12A1739 track loader. while working yesterday, I noticed a trail of fluid on the ground every so often. i checked the rearend and found that there was a hole (threaded) packed with dirt. I fished around and all of sudden, GUSH. Oil poured out of there for a short time.. I thought that there should be a plug there as it is threaded.
I went to the other side and found the same thing. a hole packed with dirt and when I poked around it drained oil out as well.
I shut the machine down and went to check my manual.. here is my problem, my book doesn't look like the rear in the tractor.
Serial # of rear is 7U40773.
I checked the transmissiona and it is over filled (from previous owner).. is it possible that i am leaking from the trans into (what i think is brake compartments) and these holes are there as drainage??
can anyone confirm if there should be plugs in these locations??
thanks
rod
thanks
rod
