StumpSlinger
What sn was the undercarriage change on the 955l and what all changed?
Basicallly the link pitch changed from 6.91" to 8.00", along with all the affected components.What sn was the undercarriage change on the 955l and what all changed?
Thanks, could you give me general info on this one sn 71j4969? Tag was missing on the engine.Basicallly the link pitch changed from 6.91" to 8.00", along with all the affected components.
As regards S/N change sorry no idea. TBH after over 40 years in service any particular machine could have old or new style undercarriage by now. All depends what an owner decided to put on it.
That machine was originally built with 6.91" pitch tracks.Thanks, could you give me general info on this one sn 71j4969? Tag was missing on the engine.
What year and would it be a 3304 or a d330c?That machine was originally built with 6.91" pitch tracks.
Whould the engine have the sn stamped anywhere on it?Can't answer as to the year, maybe somewhere around 1972. Someone else will probably have the definitive information.
If the engine is original it appears as though it is a PC version of the 3304, which appears to have been introduced at S/N 71J4558 replacing the D330C. I remember you said "no S/N plate" on the engine so in that case all
Could have. Try looking at the back end of the block close to the flywheel housing where the S/N plate should normally be located.Whould the engine have the sn stamped anywhere on it?
