D6 Merv
- Joined
- May 10, 2007
- Messages
- 658
- Location
- Coromandel Peninsula. New Zealand
- Occupation
- Self employed bulldozing contractor with a D6D D4E
yes was just going to say what wagspe said
Also rotate the bevel gear assembly a dozen times while doing the preload so the rollers actually 'seat' too. I always set the backlash up somewhere near where it should be while doing the preloads then set it right afterwards. and yes same amount of pinion shims is always a good starting point. Hope you resealed the final drive pinion flanges while you where in there, as is only another half days work![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
