966f Hydraulic Schematics
pedrocar
australia
grader operator
Hi would anyone have the Hyd Schematics for a Cat 966F s/n 8BG02280 looking for a hose from the hyd tank to a pump on the top l/h side of the transmission not shown on sis lot of hoses are not generic so no banded tags to go on
Thanks
Here's the schematic but don't get your hopes up, there are no part numbers on it ..........
Just a minuet ........ a pump mounted on the top l/h (back I assume) side of the transmission. Are you by any chance looking at the supplemental steering pump..?
  • SENR4778-02 - Hyd Schematic.pdf
pedrocar
australia
grader operator
Good chance only a thin hose about 1/2 meter long
comes from behind the steering valve on top of the hyd tank
pedrocar
australia
grader operator
No its not on there Nige It comes out next to pipe 5V0779 will have to take it in get one made its to short rubbing on the chassis
Like to get the cat hoses ,they are a lot thinner and right length with fittings that you can get a spanner to the bolts
