There are a number of Service Mags on 977 11X Final Drives. I think this is the one you are most likely referring to ...........
Description of Change: New, wider gears are used in the final drives of 977L Loaders (14X1951-Up). The new gears and pinions also have an improved tooth profile (shape), and a new gear hub is used with more bolts to hold the bull gear. The number of gear-to-hub bolts is increased from eighteen to twenty-seven. New final drive cases are used with the new gears and pinions. These improvements will extend the service life of the final drives.
Adaptable To: The new parts, used together, are adaptable to 977L and 977K Loaders 14X1-1950 and 11K1-Up. It is not necessary to install the new parts in both final drives at the same time, but conversion of one side only will cause some difference in straight line travel (movement) of the machine. There is approximately a 3% difference in the gear ratio between the new and former gears and pinions.
