grumpy mechanic
Good day, this will be my first post and would like to thank everyone in advance for their past and present help.
I have a Cat 980h JMS04131with 21000 hrs. The machine has had a recent rebuild but is having issues with the boom functions. Currently the float is not working, the boom raise and lower detent magnets at times feel "weak" and very rarely the boom lift will stop when raising and will not move up or down unless you cycle the bucket tilt. I have replaced the raise and tilt control levers and bearings as they were worn, sticking and not centering - causing the bucket to raise by itself.
I should mention I have performed all the boom lever and valve calibrations in ET and the issue is still present.
I did find a code 351 with 6 occurrences, but no active codes at the time when I went to check it out.
If anyone has had this issue please feel free to reply, as the machine is currently at the shop for maintenance.
