A25c problem
funwithfuel
Will county Illinois
Mechanic
Looks like port P5. See notes in attached document.
I've also attached electrical checks for the trans solenoids. The measurements should be at the fuse/PCB connectors. Hope this helps Good luck.
  • A25 trns hyd test.pdf
  • A25 trans fnxn.pdf
JLAVERTY1
Uk
Thanks for the help much appreciated!
The machine is away to work today but will be back tomorrow and get it checked
We have removed the front driveshaft to the front axle and the problem has disappeared
To me I think that the longitudinal diff is locked on causing the machine to fight with itself on good ground where grip is no issue, the steering is light compared to very heavy with the shaft connected, however I will check the trans retarder and see what it says
I might be wrong but my gut feeling points me to the drop box, however it’s only a guess
