Acceleration problem
Wikus
Panama
I have a Hyundai excavator robex 220LC-9S that just refuses to accelerate. Does anybody know how to test the accel actuator as i get no response from it or what else i can look for
Wikus
Panama
Also no every thing works hundred except the acceleration it does not rev up at al manually by hand yes it pics up
uffex
Lincoln UK
Admin
Good day
If you control switch looks as the illustration you can check it out with the information.
Kind regards
Uffex
  • Engine speed control.pdf
Wikus
Panama
Thanks the illustration helped so know i know my control switch is working seem i will have to replace the accel actuator
uffex
Lincoln UK
Admin
Not sure about the actuator do you have a picture of connectors also ?
Uffex
TVA
USA
Unless you turn off automatic decel. Your manual engine speed will not work! If you have problem with your potentiometer you should have a trouble code!
Wikus
Panama
Sorry had connection problems yesterday. Yes i did turn it of. i have opened the accelerator actuator box and put power directly to the small motor on the inside it does not turn at all so i suspect it must be the problem
Thanks for the help so far
Cat_man320
Hi. if you need a accelerator control I might be able to get one at least half price over what the dealer would ask. Do you have a part number, year of machine and serial number ? these are brand new , not rebuilt units .
Wikus
Panama
Hi yes i would be interested
Part no: 21EN-32300
Excavator
Model: ROBEX 220LC-95
Product id: HHKHZ614LE0006873
Please if you could send me a mail with the price to [email protected]
Musa
Zambia
Hi I have an issue with auto rev on my hyundai robex 180w-95.When levers are operated it doesn't increase Reves unless I adjust manually on the cluster,what could be the problem.
uffex
Lincoln UK
Admin
Good day
Do you have the same issue with travel?
Kind regards
Uffex
