Advice
chadS+
Wisconsin
Hello everyone. New to the forums. I'm a deck contractor and with that you need footing holes in at 4' deep. I mainly use a skid steer to auger them in. Going forward and back several times to clear the auger bit off leaves pretty good ruts in the lawns. Im thinking of swithching over to a mini excavator as I can for the most part stay in one spot and swivel the machine off to the side to clear the bit off. My question is does a mini excavator have enough auxilliary flow to power up to 24" bit. Im thinking of getting a 35 series of some sort. I never used a excavator with a auger attachment so im not sure on how well it would do. Anyone with experience with this situation id like to hear your thoughts.
Thanks
Acoals
Wisconsin
You might be better off looking into a track loader; they don't tear stuff up near as bad as wheeled machines do. I don't have experience with running attachments on a mini, but I have run a 24" auger a bit, and I kind of doubt that a 7000lb mini is really going to be able to handle that bit very well. I don't know if it is going to be able to lift the bit out when it is dug in hard.
Also, the mini is going to be useless for anything else on the job, where a track loader might be useful for moving lumber around, ect.
chadS+
Wisconsin
I currently use a track loader and it is better than a wheel loader. I'm looking to buy either a track loader or a mini ex. Depending on where im digging theres times where i had to take the loader back and get a mini to actually dig the footings because the rocks are to big. So my thought was to buy the mini and that way i would switch over to a bucket if i ran in to that situation again. But you made a good point that the mini may not lift a 24" bit out full of dirt.
I think it's a sound plan. Not having to stop when you find bad ground is a great point. You can walk right up to a spot and set the blade between you and the hole and have some pretty decent lift with a 35.
I set 1000 pound type 30 catchbasins and sling my 900 pound steel plate around easily enough. 1600 is the max.
chadS+
Wisconsin
The 35 has a lift capacity of 3200lbs so even with a 24inch bit fully loaded id have to believe it would lift it no problem. But the question is does it have enough gpm flo to run a bit that size.
Tags
Connecticut
I would think a 35 size machine would work fine. Especially if you pair the auger drive to the flow capability of the machine. Its probably a better choice than a track machine since you can dig your footings if you can’t drill them.
stumpjumper83
Port Allegany, pa
Movin dirt
Minis with augers are the slickest way to put in holes, bit dangles straight, you can apply down pressure, and you can reach over obstacles.
It does not, not at the hieght of the auger. Possibly you can find a chart that will show something like that a few feet under the ground and 2' out from the blade.
colson04
Delton, Michigan
I ran a 24" auger on the end of my Bobcat 753. (Not an excavator, I know) I don't have much auxiliary flow, or lift capacity. I just pecked away at the holes. I took smaller bites and didn't let the auger get overloaded. It worked very well and we got the polebarn footings done in pretty short order. Spent more time driving to pickup the rental bit than I did augering the 46 holes.
I think a mini would work just fine for you based off my experience. You've done these enough to know how to run the large auger, and it sounds like the added abilities of a mini would be a nice compliment to your outfit. Worse case, you're dissapointed, and sell off the mini later if you don't think you're utilizing it enough, though I don't think that will be the case.
Another thought - are you close to any rental yards that might have a mini with auger set up you could rent for a job to try out? That way you could try it first hand with minimal long term risk if you don't like the set up.
FWD
Barron County, Wi
I have a McMillan auger mounted on a KX033-4 Kubota mini-excavator. I have a 12" auger bit on it. Works fine unless a larger rock happens to be in the hole. Really nice because you don't have to move once you start the hole.
FWD
Augers don't need to turn very fast. I never even ran full throttle and did drill a couple 24" holes in clay with a skid steer. I had about 16 GPM at full throttle. The trick is to pull the auger up before it gets hard to turn. A mini-ex would be great just for that.
Put many a foot of privacy fence in over the last 30 years. Started with an auger on an Bobcat 843, then 863, then a T250 and finally a 334 mini. The mini was light years better at augering fence post holes. On small yards it could sit and hit 4-5 holes without moving.
I think you will like it.
Also moved this thread over to the Compact Excavator forum.
jrtraderny
New York
Thanks
Aux flow on a 35G Deere is 16.2 gpm which should be plenty I know I have an 18" I run on mine. The only thing that bothers it is big rocks but those bother a skidsteer too .
KSSS
excavation
How effective a post hole auger running at 16 gpm depends on soil conditions. Easy digging and sub 2' augers it would probably fine. However if the aux flow on the mini ex is running a thumb also, the psi will be turned down to allow the thumb to give to the bucket curl. Again if the soil easy, probably not an issue running around 2-2.5K psi. However its not all about GPM, the power comes from the PSI. If you happen to have dual aux flow on your mini then you can turn up the PSI on the nonthumb aux hyd. and get max PSI on the other aux. Something to think about.
16 GPM and 2500 PSI will turn a 24" auger unless there's big rocks or roots. In heavy clay soils just take smaller bites. You don't have to do it all in one shot.
PeterG
United States
Contractor
I don't know about the excavator Auger thing. We did some holes for street lamp post and rented an auger for our TB153fr from United Rentals. Worked ok.
I prefer my Toro Dingo with Auger, but that's not quite as good for wide and deep. You must build nice fancy decks! Most deck guys just throw down some pre-casted concrete blocks.
